t/a delete?
ok, i am still running a 10 bolt and want to switch to a better rearend. only problem is that i AM NOT paying 2300 for a aftermarket rearend. plus i already have a 12 bolt houseing the right width for my car plus have the right axles. i can do the fab work of swaping all the brackets over to the 12bolt but the t/a is where the problem is.
so what my plan is, to use a ladder bar setup that just replaces the lower control arms and uses the stock brackets in the stock locations. i jsut dont know how the car will hook with this kind of setup. my mods are in the sig, and the car hooks VERY good right now.
i have already priced everything i need to put the 12 bolt together and it all comes up to about 500-600 bucks.
This thread may be helpful.
I have seen a car that ran a torque arm adapter that mounted betwean the housing and the cover. Maybe that would be a solution?
Good Luck,
Daren
