Air bag replacement.
When you replace your air bags, do you just plug in the new ones and your good to go? Or do you have to replace the module also? Any write ups on replacement? Thanks, Steve.
From what I've gathered, there ARE NOT sensors that cause the airbags to blow which need replacing. Instead, I think there's a solid state electronics module, called the Sensing and Diagnostics Module (SDM), under the center console that senses acceleration. I think it's THAT module that tells the airbags to fire. In fact, that module is a black box of sorts. It records a few parameters in the last 5 seconds before the airbags blew. I'm wondering if this module needs to be reset somehow in order for it to work again? I see mixed reports on what to do as far as replacing or reusing goes. All this is just speculation on my part and is deduced from what I've read from other posts.
So basically, I have the same question. My car has been wrecked, I want to replace the airbags so they work again...what needs to be done?
Both airbags are gone from my '94, and guess who did it?
