Tom the roofer | 10-29-2006 07:39 AM | Yes I did. Just 3 weeks ago. I used teflon tape on the original install. Mine was OK for 3 years or so and all of a sudden it decided to start leaking. What tipped me off was a squeeling serpentine belt :eek2: It was the lower hose fitting, I took the hose off and to my suprise the fitting was REALLY LOOSE. I mean REALLY LOOSE. :confused:
I drained the water, cleaned everything up and used pipe paste this time. This time I cranked it tight with vice grips. I check the top fitting and it was a little loose but not bad at all.
I knicked the finish a little but it's tight now. I will check this item frequently from now on :confused: |
