Drag Racing Tech
Hood pin PLacement
Old Nov 8, 2006 | 01:35 PM
1998TA__1991RS's Avatar
Default Hood pin PLacement
I have a 98-02 style VFN Ws6 pin on hood, i have the dzeus fastener kit form jegs, my problem is i cant figure out where to mount the tabs along the front of the car. there seems to be nowhere to mount them at, help guys, thanks
Old Nov 8, 2006 | 04:05 PM
Fire67's Avatar
You'd probably have to bolt the tabs to the plastic support... Where the factory nose cover is riveted onto know, along the edge where the front of the hood meets the nose. There's rigid plastic underneath there.
Just make sure you get all the side ones bolted/welded to some metal for safety's sake.
Old Nov 8, 2006 | 09:40 PM
there is no front lip on this body style, theres just the area where the headlight doors are then the front scoop piece
Old Nov 9, 2006 | 11:55 AM
would it be ok to revit the brackets straight to the fender??
Old Nov 9, 2006 | 06:41 PM
chpmnsws6's Avatar
I tried using those things but they were just to flimsy. went to Autozone, spent 35 on 3 packages of hood pin kits, and the hood will not be going ANYWHERE now. MUCH MUCH stronger then before.
Old Nov 9, 2006 | 07:03 PM
SPEEDYws6's Avatar
No, the plastic fenders on our cars are not sturdy enough.
Here's a pic of how madman does it.
Old Nov 9, 2006 | 07:39 PM
thats nice, what does he use 1/2" tubing? i was tossing around the idea of getting some 1/2" hard brake line and welding the tabd to it and making some brackets to hold it to the fender bolts with, could this be done?
Old Nov 10, 2006 | 06:01 AM
MADMAN's Avatar
LS1Tech Sponsor
I use 3/8 chromemoly tubing with brackets to grab EVERY fender bolt. Brake line tubing is too soft and will bend too easy.
__________________
www.madmanandcoracing.com
225-343-9029
Old Nov 10, 2006 | 12:46 PM
Fire67's Avatar
Why not just bolt the tabs in place with the fender bolts? Maybe Im missing something but welding them to a bar that bolts in place seems a bit overkill. Id just drill a hole and bolt em down, one at a time.
Old Nov 10, 2006 | 01:35 PM
SPEEDYws6's Avatar
It ties them all together and adds alot more lateral strength than just one bolt on each bracket.
Old Nov 11, 2006 | 01:12 AM
ls1408cp's Avatar
madmans are bad *** but this is what I did. I just bought some 1 1/2inch strips and a piece of c channel. Did some welding and and bolted them by the fender bolts. I was going to clean them up and have them powdercoated or something but I might just leave them alone.
Old Nov 21, 2006 | 01:08 PM
jldak318's Avatar
sorry for quoting the pic but i really like this idea alot, this would be the best way for the do it yourselfers
