Drag Racing Tech
ET Drag Question, Please help
Old Nov 9, 2006 | 07:57 PM
turimo1's Avatar
Default ET Drag Question, Please help
I just bought some 28x10.5x15. I have a 1 inch narrowed 12 bolt moser and sportlines springs. The tires slide on ok except for a little trimming needed on the calipers and brackets. How much do these tires grow? Do I need to roll the fenders all the way around or just the top?
Old Nov 10, 2006 | 05:58 AM
turimo1's Avatar
anyone?
Old Nov 10, 2006 | 07:46 AM
1STGEN68-2000SS's Avatar
These tires will grow at least an inch. After each run you need to look at the front and rear of the fenders and see if they have been rubbing. We had to cut the rear fender skirt off a little and modify the front. If you cut the rear fender be sure to bend any metal around so it will not cut the tire if it does grow.
Alan
