Drag Racing Tech
NHRA at it....
Old Nov 17, 2006 | 08:39 AM
NRC-Motorsports's Avatar
Originally Posted by Nine Ball
I just wish they had a more creative name than "diaper"
they do, oil retention device
and like mentioned above, the way i interpet that rule is it only applies to me if i'm an NHRA class racer, not your regular t&t guy or even regular local track quick 8 or index racer/heads up..as those types of things usually carry there own set of rules, set by the track there held at... i'm sure alot of tracks will start pushing this for everything they run as it will help them keep the maitinence down and help keep people from wrecking there ****... this has been a rule for import series racing for a couple years now i believe, cause those guy sure like to blow **** up...
jay
Old Nov 17, 2006 | 09:26 AM
kp's Avatar
kp
jay
Pretty standard now in motorcycle racing I think too.
Old Nov 17, 2006 | 12:45 PM
94z28L's Avatar
but with a track that is nhra sanctioned wouldnt they require then on their test and tune nights that anyone running 9.99 and quicker have an engine oil retention device?
Old Nov 18, 2006 | 06:39 AM
tektrans's Avatar
I like the rule. I've spent MANY hours this year at Etown waiting in the lanes because a clean up was going on. It sucks. I think it should apply to ANY car that goes down the track. I intend to run 9's next season and I'll have no problem getting the diaper.
I have to say I've seen just as many 12 second cars oil down the track as the 9 sec and faster cars have and for the most part the faster more experienced racers are the ones that pull it to the side and get it stopped unlike the others that run it all the way down.
Old Nov 18, 2006 | 02:19 PM
Fireball's Avatar
I dont think its for a clean up time change...its more for a faster car spilling its oil and slicks hitting the tires and wrecking the car...
Old Nov 18, 2006 | 03:52 PM
1BADAIR's Avatar
turbo's now have to be in the engine compartment too
Old Nov 19, 2006 | 02:16 AM
94z28L's Avatar
is that for all cars? because if that is the STS guys are gonna **** bricks
Old Nov 19, 2006 | 06:43 AM
tektrans's Avatar
I agree, yes but it also would cut down on the clean up times too which at least at Etown is a problem many a night.
Either way I think it's a good rule.
Old Nov 19, 2006 | 07:58 AM
STOCK1090's Avatar
Folks,
"Comp" is for Competition Eliminator. I do not believe any of you guys are running in that class.
Not a bad idea. I hate being held up by a guy who blows up because their stuff is not up to par.
Now the guys who use antifreeze instead of water get me fired up. That crap is hard to clean up. If your are afraid of freezing use windsheild washer fluid.
Old Nov 19, 2006 | 08:57 AM
1BADAIR's Avatar
don't know
Stock
· Exhaust system for turbo applications, aftermarket header permitted. Turbo must be located in engine compartment.
· Crossmember may be altered for oil-pan removal.
· Weight of piston (without pin, locks, or rings) must be equal to or exceed minimum piston weight as listed in NHRA piston list.
· Roll bar mandatory on any car running 11.49 or quicker; permitted in slower cars. Roll cage mandatory in any car running 9.99 or quicker; permitted in all vehicles.
· Driver restraint system meeting SFI Spec 16.1 mandatory on any car running 11.49
Old Nov 19, 2006 | 09:17 AM
Maggie's Avatar
How about 'Engine Incontinent Device'...or, just 'Depends' for the race car!
I think that the diaper rule is long over due.
Old Nov 19, 2006 | 12:11 PM
  #32
kp's Avatar
kp
One of the reasons (at least what I heard) was to make the live National event coverage easier to manage, two or three comp oildowns and you start getting behind schedule. Of course driver safety is one thing but I doubt the rule will afeect the sportsman ranks at all.
FWIW I assume the rear mount turbo rules applies to NHRA stock eliminator cars.
Old Nov 19, 2006 | 02:24 PM
  #33
Maggie's Avatar
Yes, That was my assumption also.
Old Nov 20, 2006 | 07:33 PM
  #34
NA$TY-TA's Avatar
Originally Posted by gator's 99TA
i think a diaper is a good idea. its not like many guys DD a car that fast. its a safety issue and not that inconvienent.
Hey Now..... some of us do.... LOL
Old Nov 20, 2006 | 10:31 PM
  #35
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
Definately agree that something needed to be done, but it seems it won't catch the half-assed racers that decided to oil the entire track even when they can safely pull off the the side and stop (mostly the slower-than-9's guys)
In my opinion, if you oil it (unless you have the tires coated and you can't safely pull off and stop), then you get out and clean it up to the satisfaction of those racing that day/weekend.
I've seen quite a few wrecks due to oil on slicks from a blown engine, and I'm sure this will help.
Derek
