Drag Racing Tech
Replacement Light Weight Spindles
Old Nov 26, 2006 | 11:43 AM
N20Silverado's Avatar
I talked to a guy that was selling a 4th gen that had titanium spindles. He said he had them custom made by Trick Titanium. I don't know any more information than that.
Tim
Old Dec 5, 2006 | 01:37 PM
SlickVert's Avatar
Made a few calls today about spindle/steering knuckles
Santhuff makes set for $945 but also requires custom A-arms to be made to fit their spindle/steering knuckles
AJE makes a set of stock replacement spindle/steering knuckles for $699 that will fit stock A-arms, but will need a 3rd Gen style brake kit, like Aerospace or Wilwood.
He custom makes them and can go ½ to 2” drop (Minimum is ½ drop).
Old Dec 5, 2006 | 01:40 PM
JL ws-6's Avatar
Race your car!
Those units from AJE that require a 3rd gen brake setup actually sound like a good option as well... the $ you're spending on the spindles, you are almost saving in teh price difference from a 4th gen to a 3rd gen brake kit. look @ the prices of say strange drag brakes, the cost differnece from a 3rd gen kit to a 4th gen kit is huge!
Old Dec 5, 2006 | 01:41 PM
SlickVert's Avatar
Does anyone know the weight of the stock cast iron spindle/steering knuckles?
Old Dec 5, 2006 | 04:03 PM
1999TransamWs6's Avatar
believe they where around 30lbs each at least!!! maybe even 40!!! cant say exactly.
Old Dec 5, 2006 | 09:10 PM
CanuckSS's Avatar
I remember seeing pictures of spindles that someone had drilled out. If I remember correctly it might have been someone from Wheel to Wheel.
Just another option I guess.
Old Dec 5, 2006 | 09:44 PM
SlickVert's Avatar
Thanks, I thought of lighting the stock one as an option, like to see some pic's
Old Dec 6, 2006 | 06:35 PM
Dave88z's Avatar
Yeah, but don't forget that AJE says you can't use Strange brakes with thier spindles. They said the hat for the rotors are too deep and contact their spindles. I can't see why the Wilwood or Aerospace brakes are any different, if anyone has more info on this please let me know.
Old Dec 7, 2006 | 04:57 AM
JL ws-6's Avatar
Race your car!
There's got to be some lightweight brake setup that can be used..... the price gap is probably the same, only differnence being that wilwood just doesn't make a 4th gen kit that I know of anyway.
Old Dec 7, 2006 | 07:05 AM
MADMAN's Avatar
LS1Tech Sponsor
I used the AJE spindle setup on the 25.2 Bird I am building. Its quality pieces but the geometry was all wrong. It took alot of work to correct the issues.
By the way the kit came with Strange front brakes.
__________________
www.madmanandcoracing.com
225-343-9029
Old Dec 7, 2006 | 12:21 PM
383ss's Avatar
I saw those for sale a while back. they had 3 or 4 circular holes drilled in them.
Old Dec 7, 2006 | 08:06 PM
  #32
Dave88z's Avatar
Are you serious? I called them about thier 3rd gen drop spindle and the guy said they do not work with Strange brakes. Then I asked if they had any type of spindle that would work with my brakes-of course he said no.
I heard from a reputable chassis shop in the area that they had a few problems with AJE spindles. Do they have a lot of Q.C. issues? I'm going to call them back as soon as I get the chance.
Old Dec 7, 2006 | 10:01 PM
  #33
CanuckSS's Avatar
I found the post that has the pictures of the spindles that were drilled.
I couldn't get the pics to come up but it might work for you guys. At least I was right, it was Whitey's stuff from W2W.
On a side note, you should check out his project in the sponsor project section!!
https://ls1tech.com/forums/showthrea...hlight=drilled
