Drag Racing Tech
coilovers for 68 camaro
Old Dec 1, 2006 | 05:07 PM
68LS1WANNABE's Avatar
Default coilovers for 68 camaro
Having a hard time deciding on the right set of coilovers for the rear suspension on my 68 camaro. I'm totally redoing the rear suspension. Ditching the leaf springs for a LCA, torque arm setup. In the pics you can see where the center section has been removed to allow a shock tower crossmember to be added. It will allow the use of taller coilovers with the car's lowered stance. Hopefully allow more travel without bottoming out. Which company would you go with. QA1, Comp eng. etc...
Also some spring rate recomendations. I don't have any weights yet but they'll be coming. This car will be a all around car. fast thru the 1/4 and still be able to take a turn. Hopefully keep up with the 4th gens.
Attached Thumbnails coilovers for 68 camaro-ryanstuff-010.jpg   coilovers for 68 camaro-ryanstuff-011.jpg   coilovers for 68 camaro-ryanstuff-012.jpg
