Drag Racing Tech
what settings work best for you?
Old Dec 7, 2006 | 03:04 PM
phoenix's Avatar
Default what settings work best for you?
i have adj QA1 shocks and adj T/Q just wounder what setting works best for you guys? i'm just looking for a starting point for my car.
i just put the new goodyear DR 325/50R15 on the tire is sticking as hell but from a stop i cant hook. i know it is cuz my suspension is not set up right.
Old Dec 7, 2006 | 03:12 PM
JeffT's Avatar
2 up front, 5 or 6 out back, -2 pinion. Good a place as any to start.
Old Dec 7, 2006 | 03:17 PM
SlickVert's Avatar
Not sure of your mods but, I recommend a set of LCA relocation brackets, not sure if you have them, can makes a big difference. Install the LCA in the lower hole to start with. Your LCA should be running uphill as they go forward.
I would try this to start with
Front shock start around 2
Rear shocks start around 3 or 4
Make few passes then start tighten up the front until it 60’s best, then do the same with the rear.
Bob
Old Dec 7, 2006 | 03:40 PM
phoenix's Avatar
yea i have LCA relocation brackets but then i put the LCA in the lower hole to pulls my diff forward and i cant fit the tires.
so 2 up front wow i think i have mine at like 8 and my rears are about the same.. lol i'm way off.
