Need help launching
Any tips for launching better (maybe techniques or even adding weight in the back of the car) that i can use coming up. oh and new tires arent an option due to funds so is there anything else i can do for a bit more traction???
1. Stall up as much as you can without pushing the front tires through the lights
I have found that for me it gives me a better ET but not a better 60'
2. Stall the car up just enough to tighten the drivetrain 1000-1200. Stomp the crap out of it and it will flash to 3200. It will give you a better 60, but it may not give you the best et.
You will have to make several passes and decide which one is the best for you. If traction is an issue you will probably need to stall it up to 2000 instead of letting the converter flash.
I am trying to figure all of this out myself so maybe someone else will chime in and give you some more info........hope that helps.
I've herd of guys letting some air out of the tires before running, that this might help in getting some traction on the launch.
Neone have a claim about this or any other pointers?
