Which water pump should I get???
There are three differnt pumps. street=place for heater hose race=heater hose delete
1- 55gpm street pump
2- 40gpm race pump
3- 35gpm race pump
This car makes laps around the dragstrip. me and my grandfather double up in 3 classes each. So this car is running down the track just about nonstop sometimes.
My concern is I want to keep the car cool as possible which the stock pump does fine but I want an eletric pump so I can cool it in the lanes. I figure one of the race pumps would work since I will be able to run it with the car off but sometimes I don't have time for that. I just wonder if the 40gpm would work for this. right now the heater hose is just looped.
What do you thinK?
Also if doing power steering delete can I just use the alt. adjutable bracket and not run the belt on the tensioner or the wp and only from alt. to balancer?
http://www.jegs.com/webapp/wcs/store...61611_-1_10135
Currently I have it looped with the oem pump. but this one has removable fittings so I thought maybe I could cap them off but I don't know if it is ok or not.
I called meziere today.
thay said it came with plugs if you don't want to use the heater.
