Drag Racing Tech
light weight battery!!!!! And one question
Old Mar 9, 2007 | 07:08 PM
Getav8's Avatar
Default light weight battery!!!!! And one question
Just lost another 20lbs off of the front. Went with the Hawker Odyssey PC680.
When I went to mount the battery terminals back I noticed that there were two ground wires that bolted directly to the wheel well. One wire was about 11" and the second aboout 8". The 8" was too short to make it down to the terminal so I took it off. The car started fine and I put the lights on, everything seems fine, however I did not take the car out and drive it around. My question is why are there two grounds going to the same place and will it be a problem with only using the one?
