Drag Racing Tech
roll bar help
Old Mar 19, 2007 | 07:48 PM
911ss's Avatar
Default roll bar help
so i bought a cromo wolfe 6pt roll bar for my camaro ss vert. its in the car except not bolted down. the main hoop was ok, the front bars are being a bitch bc the bolts are comming up just short for me, now im worried about the rear. they dont line up with the seat belt bolts well at all, how am i supposed to hook these up once i get them lined up? the stock seatbelt bolts are not long enough, do i have to drill a hole all the way though that back panel or do i just neet to drill a hole and knock the nut out thats there for the seatbelts? thanks alot!
Old Mar 19, 2007 | 08:47 PM
DMH Fabrication's Avatar
You may want to call up WOLFE if your having problems. There are very heloful and more than willing to help you out with any questions. I will say that before you bolt anything down all the way get everything together loose so you can make minor adjustments to get it all aligned.
Old Mar 20, 2007 | 07:45 PM
911ss's Avatar
i talked to them today, i also bought some longer bolts, hopefully i can get it all together tonight.
