Drag Racing Tech
Welding Question
Old Mar 22, 2007 | 01:26 PM
02Z28's Avatar
Default Welding Question
What kind of gas do you have to use when welding cromoly? I heard somewhere you can use straight argon, is this true?
Old Mar 22, 2007 | 01:39 PM
Fireball's Avatar
You use a TIG welder with straight argon
Old Mar 22, 2007 | 01:43 PM
DC@CSC's Avatar
Are you planing to mig weld the moly?
Old Mar 22, 2007 | 01:57 PM
02Z28's Avatar
No it's going to be tig welded. Thanks for the help guys.
Old Mar 22, 2007 | 04:55 PM
mrdragster1970's Avatar
6 & 8 Second Club
So do I
Old Mar 22, 2007 | 08:17 PM
RDTA's Avatar
I dont know how true this is. But will throw it out there. But I was going to use co2 to tig with. I have been welding a bunch of mild steel. but the guy at the gas shop says, U cannot use anything but argon with a tig welder. He says the argon is actually used for the TIG process. If this is true or not I dont know. But I can run the welder though. lol
Old Mar 23, 2007 | 08:55 AM
smoknta's Avatar
You can use other gases for tig, but not for what he is wanting to do. You can not use C02 though, or even a C02/Argon blend. You will have severe tungsten errosion. You can use a argon/helium blend if you want a really hot burn. But I have only seen this done, in automated tig processes on large work pieces.
