Drag Racing Tech
flaming river manual rack question
Old Mar 27, 2007 | 08:28 AM
jshiver's Avatar
Default flaming river manual rack question
I have a flaming river manual rack and bumpsteer kit and I am having problems getting the tie rod ends to adjust far enough out. Is it possible that the adjuster (tube with 2-bungs on it that you twist to let the end out) is too short? I only have a bout 3/4" of threads still in the tube.
What am I doing wrong?
Old Mar 27, 2007 | 08:34 AM
MADMAN's Avatar
LS1Tech Sponsor
Is the caster and camber set?? If not then there is your problem. If it is set then how long are your adjusters?? They should be 6" long.
__________________
www.madmanandcoracing.com
225-343-9029
Old Mar 27, 2007 | 02:00 PM
jshiver's Avatar
caster and camber not set...everything on the k-member is slotted...So..I guess I will have to get a 4-wheel alignment before I know for sure then...Thanks Madman for answering my "dumb" questions
