Drag Racing Tech
soft lock style clutch???
Old Mar 31, 2007 | 02:25 PM
3pedals's Avatar
Default soft lock style clutch???
anyone running a soft-lock style clutch in their cars??? This is truly the only way to go for a drag car, but I havent seen or read of a bolt in available clutch of this style, for the newer F cars. Do you have to put in a larger belhousing and longer input shaft in the trans in order to run a push style clutch? and use a convensional soft-lock setup ????
Old Mar 31, 2007 | 11:47 PM
ls1 joe's Avatar
I have one and it fits with some modification. I also have a mcleod scatter shield. I love the way it works, it is very managable. It does ttake some time to get it tuned correctly thought, but it sounds like you have some experience with them.
Old Apr 2, 2007 | 11:36 PM
3pedals's Avatar
What mods specifically? just the larger Sfi belhousing to fit a push style clutch? did trans need to be moved back very much? and did this effect the shifterhole/mounting much???
I have never used one of theese clutches personnally, but after alot of research and helping a freind with a similar setup in a 56 chev, I am convinced that using a regular clutch for drag racing is just wasting your time, and beaking alot of parts. kinda like trying to race an automatic with no high stall converter.
Barrett
Old Apr 3, 2007 | 07:07 AM
stealth71's Avatar
Interesting. Can you inform the rest of us on this?
