Drag Racing Tech
9 second suspension??
Old Apr 25, 2007 | 04:27 PM
bifster's Avatar
Default 9 second suspension??
what are you guys running for rear suspension to run 9's??? the stock suspension seems like it can definately be improved on so that lower powered cars can runs better times. such as myself im running a stock ls1 and boxed lower control arms and relocation brakets and my slicks just dont hook because I dont have any weight transfer what will help ??
Old Apr 26, 2007 | 10:16 PM
Navy David SS's Avatar
My rear suspension (last year-some with carry over to this year, but not all). Best times last year is in signature.
ManMan adjustable LCA
Wolfe Rear Sway bar
Custom Excessive AutoSports TQ arm
QA1 front and rear shocks
BMR relocation brackets
Sub-frame connectors
Adjustable PHR
NO front sway bar. IMO one of the keys to good weight transfer is to have the car 4-cornered for weight. Mine last year sat at something like 53%, 47% rear.
You'll need to test your shock setting. No set rule, but I have QA1 front and rear, set 3 front and 6 rear. Change your tire pressure. Don't run small-*** slick on a high power engine - it'll just blow them away.
David
Old May 3, 2007 | 11:39 PM
camarokid94's Avatar
hummmm words form the master hey navy ill be at thunder sat if its not rainin doing some shake down runs since the 402. all i have is these shitty 27in et streets so they will have to work for now. maybe ill see you there
