Drag Racing Tech
Fitting 28x11.5?
Old Apr 27, 2007 | 12:25 AM
Jimmy P's Avatar
Default Fitting 28x11.5?
I am sure it has been asked alot of times..but the search isn't working..
Will a 15 28x11.5 MT slick fit without too many issues on a f-body? It will be mounted on a Prostar 15x10" rim. I currently have BFG's on my 17x11 ZR1 rims, and had to do a little work to get those fit, so I figure the slicks should fit no problem.
Car currently has almost 600 rwhp and 780torque on a Mustang dyno..but will be closer to 750rwhp in a couple of weeks, so I will deffinantly need some traction. Any help? thanks
Old Apr 27, 2007 | 12:28 AM
LC's Avatar
LC
I used 28x11.5 Hoosier QTPs.. some BFH did the trick..
Old Apr 27, 2007 | 12:30 AM
Jimmy P's Avatar
Thats good to hear. Did you have to roll the fenders?
Old Apr 27, 2007 | 09:18 AM
SiL3NtXWS6's Avatar
with a stock length rear and 7.5 backspacing, i don't think you'll have to roll your fenders unless you're lowered a lot.
I am lowered an inch in back and was able to fit 325/50/15 DRs without rolling.
Old Apr 27, 2007 | 10:29 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
You will need to grind the calipers to fit Welds. You might need to BFH part of the fenderwell just like we had to in the 90's with 5.0 Mustangs. You might need deburr and hammer in the front inside lip of the fender well by the front lca mount.
If the rear is not centered well in the car, you might need an adjustable PHB.
Old Apr 27, 2007 | 03:43 PM
Jimmy P's Avatar
It should be ok. I already have an adjustable PHB, and we had to BFH the fenderwell to get the 315 BFG's to fit. I will let you guys know how it fit.
Old Apr 28, 2007 | 12:11 AM
Ls1LikeNoOther's Avatar
I just put a set of 28x10.5's on a pro-star on a 00 Hawk, bmr adjustable lca's and PHB came in handy.. and a big friggin hammer, it has just enough clearance everywhere... went to the track today, burnouts launches top end doesnt hit anywhere, im happy!
