Drag Racing Tech
Need Help deciding what front shock/spring set to go with?
Old May 2, 2007 | 10:03 AM
PunkNPonys's Avatar
Default Need Help deciding what front shock/spring set to go with?
Well at first i was dead set on QA1 R-shocks and 275lb springs but after doing a search i have found that many guys say that this setup is too soft and that QA1 shocks are not really all that great. I need some more opinions from people that have used them and maybe even have used other setups. I have been thinking about the Strange shocks but i do not know what spring to run with them. I am torn between these two setups and i do not know which to spend the money on. Any help would be apperciated. Thanks
Old May 2, 2007 | 01:28 PM
Out1aw's Avatar
for a cam-only street car, just leave it stock.
Old May 2, 2007 | 01:42 PM
SiL3NtXWS6's Avatar
I am running a 300 lb spring QA1 non-r . Car has iron block, but car is light overall and they are not too soft. On 7-8 they feel pretty firm.
Old May 2, 2007 | 05:38 PM
PunkNPonys's Avatar
Anyone else? I think i might just go with the QA1 Rs and 275 springs. I will just try to lighten up the car as much as possible. There are a lot of guys running this setup that are running in the 9s and 10s successfully.
