Drag Racing Tech
MT 275/60s??
Old May 13, 2007 | 04:52 PM
TN94Z's Avatar
Default MT 275/60s??
I can't for the life of me get these things to hook. I have tried multiple air pressures, shock settings, and different burn out styles. What is the ssecret to hooking on these things? I got it to hook pretty good once but only left at like 2k. I want to leave off the brake and just don't think they will hook at all.
Old May 13, 2007 | 04:55 PM
1QuickT-A's Avatar
Nice smoky burnout, anywhere from 15-20lbs of air pressure, and the correct shock setting should get it done.. Your car being cam only with no power adder it should hook easily on those tires..
Old May 13, 2007 | 05:28 PM
Mr.MartyStone's Avatar
20-22 psi, quick light burnout.
Old May 13, 2007 | 05:42 PM
TN94Z's Avatar
I have tried the quick light burnout, but not at those psi levels. I have always ran my DRs in the past at close to 15psi. Do these like the higher psi levels?
Old May 13, 2007 | 07:55 PM
Charles Cyrus's Avatar
Nice smokey burnout, anywhere from 15-20lbs of air pressure, rear shock setting, driver side 6, pass. side 7, front on 2. Best 60ft. on motor off trans-brake (4600rpm) was a 1.49. Footbrake on spray (1/2 delay) 1.44. I love these tires!!!
Old May 13, 2007 | 08:33 PM
TN94Z's Avatar
On the pass where I left at 2k on the footbrake I had a 1.48 60ft. So it left hard, but there is alot left in it I know.
Old May 14, 2007 | 12:31 PM
ALL UC2's Avatar
try some relocation brackets in the rear of your car if you still have it lowered. the bars are pointing the wrong way. they need to be level. i will almost put money on it that it will fix your problem. ......what you running in that thing now anyway??
Old May 14, 2007 | 01:01 PM
Darracq's Avatar
I have to leave around 1500 with a 3600 stall..If i bring it up more it spins bad, but i have a malibu and not a f=body
Old May 14, 2007 | 02:50 PM
TN94Z's Avatar
The best so far was a 6.99 with a 1.48 60ft at about 97mph. But like I said, that was almost playing with it out of the hole. I have some relocation brackets at the house but haven't had a chance to get them on.
Old May 14, 2007 | 03:26 PM
Matt D's Avatar
Retired Street Racer
I run 12-15 HOT in my 275/50 depending on track prep. 0 on the front QA1s and 50/50 on the rear Comps. Stock Internals, on motor.
