track results, a little help please
r/t .154
60' 1.64
330' 4.619
1/8 7.099
mph 98.86
My setup consists of NX DP kit ,Ported AFR heads 217 cc, ported lt4 intake,37lb injectors, 58mm t.b. , 240/246 cam, th400,art carr 3600 on t-brake na, hals shocks, skinnies, m/t 28 x 10, 3.73 gears. My raceweight with me is 3400
Last year when I had my vig 4000, I cut a consistent 1.47 - 1.50 60'. I played around with the shocks and tire pressure. I was running 10 lbs in slicks cold. This was on 150 shot, so If I can get my 60' down to where it was last year, ill be running faster on the 150 than the 250. How much pressure are you guys running in your tires that have t-brakes and nitrous. Do you guys think I could have a 10.50-10.60 car on the 150 shot? What else can I do to get my 60' times down? Thanks in advance, Chris
