Drag Racing Tech
First time track questions
Old May 22, 2007 | 09:21 PM
Ricks99ls1's Avatar
Scammer Alert!
Default First time track questions
Hey everyone i was wonderring, on my burnout i should drive around the water pit and then back up till my rears are in it, and burn out is that correct, i have street tires. and when lining up there is a prestage, then staged, then the lights will go? what color are the pre and staged lights? i have an m6 and when i go i will have my 410's installed with my 10 bolt rear, what is your guys best suggestion for launching? any help i would really appreciate
Old May 22, 2007 | 09:54 PM
mrdragster1970's Avatar
6 & 8 Second Club
With deep treads on the fronts, you should back in. Nobody usually does, but you should so you don't drag water to the line. If you do back in, go back slowly into the water, and come back out a couple of inchs. Stop out of the water, but where it's still wet. We just had a thread on this & most guys that have been around, burnout starting in 2nd it sounded like. That's what I was taught. Have fun, be safe.
Old May 22, 2007 | 10:24 PM
Ricks99ls1's Avatar
Scammer Alert!
with the 410's they burnout in 2nd right ? cause first is so short
Old May 23, 2007 | 03:21 AM
JUICED96Z
Guest
Posts: n/a
See my sticky........
Old May 23, 2007 | 07:27 AM
Navy David SS's Avatar
The sticky up top of this forum will answer all your questions, that's why it was put there to help.
David
