Suspension Setup?
My question is, how important are the different components? As in, what would be significant on my full-weight car?
Also, would a sway bar be very significant? I've been told that since I only go to the track a few times per year and just to run not to compete, that a rear airbag would be fine instead of a full expensive swaybar.
Use the search and you'll see numerous trend on the same topic.
David
Also, if only doing a little at a time, is a beefier rear sway bar more important than doing the shocks? I am considering doing the rear CE shocks anyway since they're cheap and proven. But is a sway bar more important than the front shocks?
maybe cause thats the shocks they have
i got 1.53 60's with lowering springs, no relocation brackets, front swaybar, stock shocks, and 16" et streets with a t56.
all it had was lca's and a jegster torque arm. 376rwhp.
yeah that is true. but i meen thats the same thing with saying any other performance mod or anyhting in life. you get something for a reason b/c someone else has shown something good w/ the product. everything has to come from somewhere
Other than removing the front swaybar, it's the best mod you can make to hook. (well other than tires). The springs are a waste, I used the prokit with good success. I think the stockers would be a great setup and adjust your ride height with the QA1's in the front.
