Drag Racing Tech
Double pass vs Single pass radiator
Old May 25, 2007 | 10:41 AM
Phil99vette's Avatar
7 Second Club
Default Double pass vs Single pass radiator
Any of you guys running double pass radiators? I am looking at them now because I heard that they cool better.
Phil
Old May 25, 2007 | 10:43 AM
1fastWS6's Avatar
I have a double pass Ron Davis rad. in my '68.....and yes, the double pass is supposed to cool better.
Craig
Old May 25, 2007 | 01:04 PM
ls1 joe's Avatar
I have a AFCO double pass in my car and it cools better than the stock one did. It is a AFCO radiator. The one I have is for a dragster, it is tiny. 3inch wide 24 inch width and 13,5 tall I think is the dimensions. I can let the car idle and it will never get over 160 with the fan on.
Old May 25, 2007 | 02:02 PM
DMH Fabrication's Avatar
what cfm fan are you running on your car?
Old May 25, 2007 | 05:42 PM
mrdragster1970's Avatar
6 & 8 Second Club
Good choice, same weight, same size, better cooling.
Old May 25, 2007 | 08:26 PM
ls1 joe's Avatar
1700cfm I think it is a Spal fan, I tried the Flexalite fans and they would last about 10 passes and break the blades. The Spal fans are expensive, at twice the cost of a flexalite fan. I think my fans is a 14 or 15 inch fan. I will look for the part number.
Old May 27, 2007 | 07:09 PM
Thanks for the info. I'm runnign a perma-cool 3000 cfm pusher fan with a shroud and can't seem to keep my car under 200 at idle with a 160 stat and a big afco dual pass radiator. I guess i need to add a puller fan on the backside also.
