Drag Racing Tech
Why did I loose 5 MPH in the 1/4?
Old Apr 29, 2003 | 02:08 PM
MBC Racing's Avatar
Default Why did I loose 5 MPH in the 1/4?
I changed the subject on this hoping somebody has an answer for me. I expected some decrease in speed, but not -5mph.
I went to the track a couple weeks ago and ran 12.5@121mph on street tires with a 2.16 60'. The weather was around 40 deg and dry with a slight tail wind. I went to the track yesterday on ET Streets and skinies, weather in the 70s and a 25 mph head wind. I only ran 11.85@116.65 with a 1.69 60'.
Could a head wind slow me down that much along with the warmer weather? I have to log for knock, but definitely didn't hear any. I launched at 5000 rpm basically side stepping the clutch.
I ran a couple of passes each day and they were all consistant.
Any help is appreciated.
Thanks
Brad Oblak
Old Apr 29, 2003 | 03:40 PM
Nice4thgenZ's Avatar
Default Re: Why did I loose 5 MPH in the 1/4?
if the car was spinning with the street tires on it then the mph will be higher than if the car was hooking, plus i lost about 2 mph by using et streets instead of nittos
Old Apr 30, 2003 | 11:18 AM
niphilli's Avatar
Depending on the air (DA) you could definately loose a couple of MPH, same with the head wind. What did others at the track say? Were they trapping lower than usual also?
