Where is my mph
My car is runing a 10.50s @ 126 on a cool 60* night...... im traping 7500rpm accros the line @ only 126 with 4.30s gears and a 28in tall tire.... i had fuddel tighten tyhe converter up and no diff i can still get it to go to 5800 on the brake.... is the converter the problem?
David
So you're looking at 10.2@129 and about 104 in the 1/8 (sounds like some TA I know
) with the converter as it sits.Solid roller with that compression-car SHOULD be in the 9.9? range at least.
Shave the weight and call Neal Chance for the converter. I took .08 off my 60' and almost .2 off my ET when I put their converter in.
If you can get .2 off your ET with it, you just may get that 9.
My car weighs around 3400lbs maybe a little more and with a 408, AFR 225s, small hydraulic NITROUS cam (246/254 .613/.613 113), half *** tuned, short shifting at 6700rpms with a 3.50 gear (28in tire) & 4500 nitrous converter and no trans brake will trap 125 every pass. Goes 102 in the 1/8th and 125 in the 1/4 with a measly 1.61 short time. I'm sure if I got the tuned nailed down for good, move the timing from 26 degrees to 29 degrees and start shifting it at 7200-7400 rpms that it would run closer to 128-129mph with ease.
Derek
Derek
car should run beter then it does hands down
Derek
In hot humid air (+1500 to+1600 DA) @ 3440#s I run 6.52-6.53 @ 105.0 in the 1/8 and 10.2s@131-132mph.
That's through a 4L60E,12 bolt w/3.90 gears,29.5" tire and a 4500ish stall. The altitude may also play a role if you are at good bit higher elevation.
