Drag Racing Tech
ABS & PS removal
Old May 28, 2007 | 07:17 PM
The Hammer28's Avatar
Default ABS & PS removal
Can someone who has the ABS and PS removed on their car tell me how it drives on the street? I want to remove the PS on my 99Z, but I want to keep my stock 16" rims, which may make it a little harder to turn. I don't think the ABS should be an issue, but you tell me. Thanks.
Old May 28, 2007 | 08:01 PM
smoknta's Avatar
ABS is no big deal. I would think it might be a little tough with no PS on stock rims.
Old May 28, 2007 | 10:33 PM
2002_Z28_Six_Speed's Avatar
You can remove the pump motor on the back of the ABS module and the black plastic piece from the front of the ABS block. It will end up about the same weight as an ABS delete block for on the cheap. Drives fine as long as you are used to non ABS cars.
I drove cars w/o power steering, power brakes, abs, air bag, power windows for a long time in many situations and never died.
Old May 28, 2007 | 10:40 PM
drumbo87's Avatar
I just finished my 96 lt1, big cammed 383 and i took the ps, cruise, abs, traction control all out. I have skinnies which makes it easier, but the car still turns fine. i dont struggle at all making a tight turn.
