Lazy Convertor / Madman HELP!!
Brian, you sold me the TH400 tranny kit a few years ago, and I'm not sure if the convertor I needed then is the same that I need now. Before I was just going to shoot a 150 shot through a stock bottom end with heads and cam. Now it's a 12 to 1, 382 Stroker with roller everything.
Do I need to start planning a converter change? What should I get? What do you think my current convertor is worth, considering it has about 5 miles on it. Also is it possible that the converter is just tight because its new and this is causing a "lazy" condition???
HELP MADMAN!!!
I guess I did answer my own question. I will get it back to Omaha and pull the tranny and get it restalled at TransKing. I left a message for Gilbert to call me. The new motor has strained my budget beyond belief. I'm going to have to skip some luxuries for a few months to make up for the $1000 bucks in extra repairs etc. at Speed Inc.
I can't wait to get the car home, and not have enough money to put race gas in it. This whole thing has turned into a nightmare.
1. The tranny/converter was supposed to have some sort of spacer to work with the LS1. Speed Inc said it screwed up the tranny and sent it to FLP for a new pump.
2. One of the fuel injectors wiring was bad and that had to be fixed. This was while it was on the dyno so there goes another $$$$.
I should of collected stamps, or done something cheaper like build a ******* Craftsman Truck to race in NASCAR.
