Drag Racing Tech
Launching!!!!!!
Old Jun 8, 2007 | 07:42 AM
SunshinePerformance's Avatar
Default Launching!!!!!!
Ok this is what I got my camaro (402, 248/254 612/622, 90/90, 6spd, 4:10 gears, 28"MT tire) pulls the front tires off the ground at launch but then drops down to 2200rpms or so. I'm launching around 5700-6000rpms, its getting 1.7-1.4 60's and only running 11.9 @ 119mph. The car had an alum flywheel that was replaced thinking it was the problem and now its slower. I had gone 11.4 @ 121 before.
Mike
Old Jun 8, 2007 | 08:26 AM
Ranger's Avatar
King of the radial tires
Not giving us much to go on. More to an ET/Trap than a 60'.
Suggest posting some slip elements before and after.
Same track and time of year?
How many passes have you made in the car?
Ranger
Old Jun 8, 2007 | 02:07 PM
Gary Z's Avatar
Dropping from 6000 to 2200 at launch is a bad bog. You are bogging because you’re your big 28-inch tires are hooking and your clutch is not slipping enough. Are you side-stepping the clutch? If so, you might get better results by simply lifting your left foot instead. Slowing clutch engagement slightly could be all that is needed to avoid the bog.
Old Jun 8, 2007 | 02:36 PM
When I launch it is pull my foot aside at let her go! I will try a set of 26" 10.5 tires this weekend to see if it is tire or what.
Old Feb 8, 2008 | 11:36 PM
LS1Silverado05's Avatar
I would also try the smaller tire, but I would try more clutch slip.
Old Feb 9, 2008 | 07:04 PM
RAGENZ28's Avatar
Call me stupid, but why would your motor drop to 2000 rpm when you are leaving at 6k and have enough power to run 121 mph in the 1/4?
A 28" tire isn't big, are you leaving off a 2 step with it floored at 6k or reving to 6k, dropping the clutch then hitting the gas?
If you don't have a 2 step, stage up, wait for the lights to drop hit the rev limiter with the gas floored and side step the clutch
Old Feb 10, 2008 | 10:10 PM
camarokid94's Avatar
id also guess a 26 would help.
back in my H/C days running 11.9s at 119 id drop at 6200 and bogg to 2200 i did end up slipping it and dropped about 2ths and i had a 27in ET street.
Old Feb 11, 2008 | 04:57 AM
JL ws-6's Avatar
Race your car!
I'd try putting a couple lbs more air in the tires first, get them to spin a revolution or so, either that or play the clutch slipping game, which then turns in to the clutch swapping game.
Old Feb 11, 2008 | 08:30 AM
BMR Suspension's Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
This would be my recomendation also...
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
