Drag Racing Tech
What cable to use? Carb style intake?
Old Jul 21, 2007 | 03:11 PM
stevemilz's Avatar
Originally Posted by 69vette
If you look at the bolt pattern on the actual intake you can clearly see its not a sb2 or 2.2 intake.
Im sorry for the jack Noyzee..........
http://www.tick-performance.com/customers/shopcar/
I found the GM High Tech Performance mag - August issue 2007 and it is a "SB2.2 from Pat Musi Performance"
Old Jul 21, 2007 | 07:46 PM
Jonathan@Tick's Avatar
LS1TECH Sponsor
I was told it was an SB2.2 intake. The topend (heads/intake) was an old eastside performance setup. They suposedly had the intake adapters made by Musi Performance as well as the intake modified to match up with the c5r heads. I purchased the engine used not too long ago from a member on here.
Whatever it is, I know it works. Right now we're making a few changes to the bottom end and cam to make it our own...hopefully near the 8's by october.
Old Jul 22, 2007 | 12:46 AM
DMH Fabrication's Avatar
They must have added some additional lugs to your intake then. A sb2.2 intake def. does not have 2 bolts in it in front of the 1st runner like yours does. I have one sitting here right now to look at. Good luck with your car
