Drag Racing Tech
ms4 cam time???
Old Jul 23, 2007 | 04:19 PM
formula402's Avatar
Default ms4 cam time???
have any of you guys gotten any cam only times yet at the track. what did you run and what mods do you have other than the cam.
Old Jul 23, 2007 | 05:09 PM
Trev_SS's Avatar
i would also like to know myself
Old Jul 27, 2007 | 02:40 PM
lt1formula2000's Avatar
me to i just sold my MS4 car and never got to take it to the track. I've been wondering what it might have ran
Old Jul 27, 2007 | 03:02 PM
Jefro6996's Avatar
Ill be posting up some times next sundau once the 9'' gets installed with some 325/50/15 drag radials. Hoping for an 11.0 at 124-125
Old Jul 27, 2007 | 07:32 PM
4yall2nv's Avatar
my friend with his almost stock m6 ls1 was running a 12.6 with minor minor bolt ons and then after he put in the ms4 he is running 11.8's, that is a big gain.
Old Jul 28, 2007 | 10:24 AM
nunleysz's Avatar
any more?any a4 cars?
Old Aug 1, 2007 | 06:50 PM
Sluggish's Avatar
I ran a 12.04 at 118.78 w/ a 1.87 60ft. 6 speed stock gear. It was hot and very humid sunday. race weight is 3560
Old Aug 1, 2007 | 07:08 PM
blk00ss's Avatar
Nice. I hope I can crack into the 11's. Im in the process of installing mine now, GD rounded rocker arm bolt!
Old Aug 1, 2007 | 07:17 PM
RobbieTransAm's Avatar
Very nice. How much power are you making?
Old Aug 2, 2007 | 06:25 AM
Sluggish's Avatar
I made 410rwhp and 382rwtq with a ls6 intake and untouched TB. Now I have a Fast 90/90 setup so I'm guessing 425-430
Old Aug 3, 2007 | 06:47 PM
formula402's Avatar
any A4 with any track times?
Old Aug 9, 2007 | 07:55 AM
nunleysz's Avatar
anyone?
Old Aug 9, 2007 | 09:08 AM
4yall2nv's Avatar
im pertty sure in a a4 with the ms4, and a good stall u will run a bit fater than these m6's at the track!, thats just my 2 cents!
Old Aug 19, 2007 | 10:27 PM
cholic's Avatar
I have a cam only car in austalia, its like a 4door version of the gto we shipped to the USA. We have had 3 cams in it now.
2nd cam
232/234 112 lsa off the shelf comp, 918 springs, 5000 stall, 3.9 gears, ls6 manifold with 1200cfm t/b, 1 7/8 longtube pipes,
235/60/15 mt radials, 3600 with driver. made 371 rwhp.
11.55 @117.28 with a 1.594 60ft.
3rd cam
ms4, setup unchanged except 921 springs, made 395 rwhp and 399 rwhp with a fast 90/90.(the increase was not just top end either) we were impressed with the dyno result.....24rwhp going from a good size cam to a big cam.....but
11.49 @118.14 with a 1.593 60ft. (in slightly better weather)
we thought maybe the big stick needed a hand so 4.11 gears and a very tight 6000 stall were fitted.
11.38 @119.08 with a 1.541 60ft
The MS4 showed great numbers on the dyno but at the track....not that impressed.
will try another stick soon. big hp doesn't mean big mph!
Old Aug 20, 2007 | 12:25 PM
blk00ss's Avatar
I went 7.68 with a 1.68 60ft. Only other mods are ls6 intake, LT's, TD's,P&P Throttle body. I have a six speed inc. rebuilt tranny with Spec 3 clutch, and billet steel flywheel. This was with prostarts all around, and I was on M/T slicks. 26x10's. Leaving at around 5k dump. Also with a slipping Aurburn posi unit in my 9". Oh yeah 3.90 gears.
Should be good for mid 11's I figure?
Old Aug 21, 2007 | 06:57 AM
WHPLASH's Avatar
We need to go out and run and take a video before this weather turns.
Old Aug 21, 2007 | 06:25 PM
Finally going to the 1/8 on Friday with the new clutch. Hoping for a 7.50ish at 95 or so. It's still hot though, but we will see.
Old Aug 22, 2007 | 10:05 AM
blk00ss's Avatar
Make sure you let us know what you run robbie. That is pretty high hopes. And I'm guessing you are on stock rear end?
Old Aug 22, 2007 | 02:48 PM
Yep, stock rear and 3.42 gear. Car went an 8.10 @89.95 with just lid and LTs making 341 and 358tq back in the fall. Now it is making alot more power, and weighs about 150lbs less, and that was on street tires, I will have the ET streets on Friday, but the heat will be the killer. If I break the 10bolt, just gives me a good reason to get a Moser 9" and a 4.11.
Old Aug 22, 2007 | 05:01 PM
blk00ss's Avatar
I got a feeling you WILL break the 10 bolt. I went a 8.12 before I installed the cam, and the best i could get out of mine was 7.68. That was with a 4500K clutch dump on slicks(1.68 short time). Still spinning a bit(need more suspension). I think with the weight reduction you can hit 7.50's! I think maybe I can get 7.30's-7.40's when it gets cooler. Oh yeah those times where when it was about 90 degrees, and very humid.
