Drag Racing Tech
Tire Pressure At The Track?
Old Jul 25, 2007 | 04:34 PM
Bill'sWS6's Avatar
Default Tire Pressure At The Track?
I just went from running 17X9.5 ZO6 Motorsport rims to 15X10 rear and 15X4 front ProStars. I was able to shed about 100lbs in rotating mass. So, I can't wait to see what new times I get. I ran a best of 11.98 last year.
Anyway, with my old setup I ran 275/40/17's MT ET Street Radials and lowered the pressure to about 20lbs at the track. This worked pretty well for me. Now I am running 275/50/15 MT ET Street Radials. I was told I should not have to drop the pressure as much because of the taller sidewall of the new rear tires. It was suggested that I start around 28lbs and work my way down from there. I figure dropping 2lbs at a time would work best.
So, who runs a similar setup and what do you find works well for hooking tire pressure wise? The car makes about 436RWHP and 410RWTQ on a dyno jet.
Oh yea, any ideas on what I can expect for improvments in my times going from what I had to the new setup? I was hoping to see .20 better times?
Thanks in advance for your help!
Bill
Old Jul 25, 2007 | 08:42 PM
transamfreak01's Avatar
i would just try it for a run and then lower after each run a little depending on if you spinning or not
