pic of my launch and results
60' 1.756
330 5.001
1/8 7.632
mph 94.47
1000 9.912
1/4 11.799
mph 120.38
this is 456 rwhp, see sig for motor. i went 11.55 @ 118 with stock heads and an f13 cam. just seems i should be running quicker.
you dont want the car to lean back you want it to drop the axel/seperate it from the body and hold it down there...
What does the car weigh, have you removed the bumper support yet? that seemed to help my car alot, any weight you can take off teh car is good, taking it off the front is better, in front of the front tires, the hardest weight to lift from the back, will help the most.
If you can, get an adjustable tq arm in there and put a little pinion angle to it, another thign I highly reccommend is the bmr or some type of crossmember to mount the tq arm to. This will keep the tranny mount alive alot longer, and will help the chassis not absorb some of the hit too, should help get the car moving better.
Goign softer on the rear shocks will cause more rear sag and will most likly not help unless you are spinning, if you are bogging it will not help at all.
If you have the blowproof bellhousing, try launching higher... I caution everyone with a stock ar to get the mcloud bellhousing, a pita to install yes, but it will keep your feet attached if somethign bad were to happen, which becomes alot mroe likly when you launch the car really hard IMO.
good on the crossmember, that helps. What holes do you have teh arm mounted in, and do you have relocation brackets on? Trying to determine your instant center... moving that will help the car hook up too.
Find out what hole you have the tq arm in, I assume you have the lca's one hole down from stock. if so good. Try moving the tq arm down a hole from where you have it, see what that gets you, if it got worse, then go up from where it was.... experimentation is the only real way.
Next time you go to the track, put the front shocks on 2 (1 being the loosest setting), set the swaybar with no preload at all, put the left rear shock on 5, right rear on 6, 12 psi in the tires, and try leaving at 5000. See what that gets you, if it hooks and leaves decent, then try leaving at 6000. If it spins, then try moving the tq arm bracket lower/higher.
Agree with setting your shocks a little different - 2-3 in front; 6-8 in back. Get an adjustable TQ. Get the pinion down to about -2. How's the track's condition. You should be able to launch a lot higher than 4000.
As MadMan always says: girls squat, race cars don't.
David
On the hals turn the *** all the way counter clockwise on the fronts and one click to the clockwise direction that is setting 2 for the front. On the rear all the way counter clockwise and 6 click clockwise that will be setting 7 on the rear. Also on the qtp tires air them down to 11psi warm. Also how old are the tires were they used did you get them new tires are only good one season then throw them away no matter how warn the are. Let us know how it works out. You will geed to get it to leave with more rpm otherwise it wont leave hard enought 5200 is a good starting point.
60' 1.756
330 5.001
1/8 7.632
mph 94.47
1000 9.912
1/4 11.799
mph 120.38
