Drag Racing Tech
Torque Arm Question - "Instant Center"
Old Aug 4, 2007 | 11:17 AM
9T7 Trans Am's Avatar
Default Torque Arm Question - "Instant Center"
I was reading in GMHTP and there is a great article about the MADMAN suspension components. The article talked about setting your adjustable torque arm up properly to give the desired pinion angle. Mine is set to -2 for an automatic car.
From the article:
"The number one component to make sure the tires don't unload, spin, or hop is the TA......I can alter the TA angle so that the INSTANT CENTER can be set up in relation to the ride height, allowing the car to transfer power properly."
Can someone explain to me what the INSTANT CENTER means along with the relationship to ride height?
" Simply measuring a driveline angle (difference between driveshaft and pinion angle) can lead to pinion angle setups that are inapproperiate for the car."
How can you tell if your geometry in not set up correctly?
Background on my car:
Bolt-on LT1
Vig3200 Converter
3.73 gear
BMR K-member
BMR Boxed LCA's
BMR LCA Relocation brackets
BMR Adjustable Panhard (Older version)
BMR Adjustable TA
UMI TA Relocation Kit
Hotchkiss Lowering Springs
OEM Decarbon Shocks
Best 60' thus far 1.80
Old Aug 5, 2007 | 02:35 PM
Anyone?
Old Aug 6, 2007 | 10:18 PM
chuckyt1's Avatar
Here's an article about "instant center". It's about four link suspensions but it might help you get a better understanding of it. I don't really understand all of this suspension science and tend to just listen to folks like Madman...
http://www.raceglides.com.au/TechInfo.htm
Old Aug 6, 2007 | 10:34 PM
Thanks for the link, I appreciate it.
