Drag Racing Tech
6 point cage?
Old Aug 4, 2007 | 09:59 PM
01BlackCamaroSS's Avatar
Default 6 point cage?
how much weight would i gain by having a wolfe 6point roll cage installed in my fbody and would would the cost be just for install?
Old Aug 4, 2007 | 11:07 PM
NHRAFORMULA00's Avatar
dont know about the cost of an install,but a mild steel bolt in weighs 80,lbs.cm is 15lbs lighter.
Old Aug 5, 2007 | 01:22 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
As mentioned, most bolt-in/weld-in 5-6 point mild steel roll bars will add between 50-80 lbs of weight depending on configuration. Install prices will vary depending on shop rates, ask around your area, fellow racers at your local racetrack who have bars in their cars, or try posting up in the regional forums.
Derek
Old Aug 5, 2007 | 03:54 PM
bgblockelcamino's Avatar
don't be surprised if your car runs faster even with added weight
the chassis will respond much quicker. If you can i would try to go for 8 point. connecting all your chassis points is key to a good cage.
Old Aug 13, 2007 | 01:58 AM
roadtrip120's Avatar
My wolfe Chromo with plates was 60 lbs
Old Aug 13, 2007 | 04:12 AM
jmill96Z's Avatar
It's not a tough install. Just watch out for the fuel lines on the front drivers side mount. Trust me, I found out the hard way.
Old Aug 14, 2007 | 01:19 PM
heavy6.0's Avatar
yeah it is pretty easy. but i guess it depends our your abilities.
