Drag Racing Tech
Need lug nuts pics on car!!
Old Aug 5, 2007 | 06:36 PM
erikthegoalie's Avatar
Default Need lug nuts pics on car!!
I just bought some weld prostars....
Want to see what lugs and washer set up you guys have and what they look like...post sizes if you have em too!
I have longer ARP studs on order and was told to use 12x1.5 lugs....what lengths though? Want to be track legal!
THANKS
Erik
Old Aug 5, 2007 | 07:06 PM
sixvi6-camaro's Avatar
You would need 12mm x 1.50 RH thread, 1.380 in. shank length, open ended lug nuts. Weld part # 601-1422
Old Aug 5, 2007 | 07:20 PM
great info...thank you!
Old Aug 5, 2007 | 10:54 PM
ls2 bait's Avatar
THANKS
Erik
if u will be going thru tech they need to pass atleast the diameter of the stud into the lug nut head. i.e. and 12mmx 1.5 stud would need to pass 12mm in the head of the lug nut. i used closed end lug nuts on mine so they dont even look
Old Aug 6, 2007 | 03:22 AM
jmill96Z's Avatar
I've actually had to pull a lug nut before because of that rule. I won.
