Drag Racing Tech
cooling between rounds
Old Aug 10, 2007 | 06:24 PM
omcar's Avatar
Default cooling between rounds
when bracket racing in the summer how are you cooling down between rounds? I have a 160 therm. and slp manual switch for fans..but when I only have 10 minutes between late rounds the car stays hot.. any ideas? Thanks
Old Aug 10, 2007 | 06:57 PM
kp's Avatar
kp
electric water pump and a switch on the fans, the 500.00 solution Takes about 3 minutes on a 90 degree day to get my car from 200 to under 160 degrees with the fan and EWP running. Tough on the battery though with stock fans on full blast, I just have a single 16" lowest CFM I could find fan on the car.
Other then that that you can leave the fan run and start itevery couple minutes to circulate the water in the radiator..
Old Aug 11, 2007 | 04:10 PM
omcar's Avatar
Which electric water pump should I get and will it be streetable as I drive 30 miles each way to the track...Thanks
Old Aug 11, 2007 | 04:43 PM
kp's Avatar
kp
There is only one electric pump that bolts on, it a mezeire street pump, downside is it isnt cheap.
Old Aug 11, 2007 | 06:00 PM
tektrans's Avatar
You can get the Stewart pump. It works great for me.
