Drag Racing Tech
Need input on hooking at the Track
Old Aug 10, 2007 | 11:47 PM
dnkynrbk's Avatar
Default Need input on hooking at the Track
Just installed my new moser 12 bolt with 411 gears running a A4. Motor info in sig. Im running a m/t ETdrag 28 10.5 15 tire at 11lbs air with tubes and torque arm setting is at pivot angle drive shaft at 0 on the bottom end and the bottom of the torque arm under the rear is at.
-2 pivot angle running a window switch on the n20. Set at 3000rmp and shutting off at 6400 rmp. QA1 R FRONT at 1 REARS set at 6 and 7 my 60ft is a 1.56 and stalling the car to 2000 with a TCI billet 3500 stall. The front is comming up off the ground 8inches and then the car breaks loose for a little bit hooks then when it shifts to 2nd the car is spinning and the rear of the car kicks out a little to the left probally breaks looks for about 6ft or so then hooks and takes off again. Im running out of gear on the top end probally between the 1000 ft amd the 1/4 mile market I would like any imput whether it be gears or tire height thanks guys. my previos set up was with a 10 bolt 342 gears with a 1.47 60ft.
Old Aug 11, 2007 | 06:51 PM
dnkynrbk's Avatar
anyone
