Plastic inner fenders?
I've already pulled the cruise and traction control systems out, pulled the front bumper support and the foam, yanked the front sway bar and all the brackets and had the SJM abs delete kit installed. I also pulled the fog lights and their brackets and got rid of the SLP grill insert. I'd really like to trim the air dam where it extends past the frame horns, get rid of the plastic pieces that attach to the bottom of the bumper and chuck the inner fenders. I'm not ready to start cutting any metal yet, just unbolting stuff.
Marty
when i ran my best back in april i removed the air dam....since i too have the front bumper support and foglites out. and was getting air from the foglite holes. did you ditch the A/C yet? that was another 30lbs as well.
-brandon
-brandon
the only down fall i had to having the air dam off was that now the plastic pieces undernieth the front were just dangling. so i used duct tape to keep it in place.
also dont know if this helps the camaro guys like yourself, but i also removed the side mirrors when heading to the track, all about aero. and i had the front of the nose taped up as well
-brandon
I like the idea of painting the inner area black though, it's a cool idea but for me the inners are staying.
With the iron 408 you're gonna have to set the front setting to "0" and you'll be getting plenty of travel with those fronts in the air and everyone will see that you took them off, hehe.
-brandon
I'm not going to pull the a/c just yet. My car is a hard top, so it's a little lighter than a t top car anyway. I think I'm going to pull the air dam as well. I've got the grill off already so air flow should not be an issue.
Marty
Take care. Dave
Take care. Dave
