Drag Racing Tech
can you launch a 6 spd in second gear???
Old Aug 15, 2007 | 07:24 PM
PRAY HRD's Avatar
Default can you launch a 6 spd in second gear???
hey guys.....
this may sound like a strange question, but for the sake of traction and a 1.78 ratio, i would imagine i may likely get a better launch with my somewhat light car running a 4.56 gear/27" tire combo. is this ok to do? i would like to know if the trans can handle it more than anything.
anyone ever tried it with slicks or similar?
thanks.
Old Aug 15, 2007 | 08:28 PM
gator's 99TA's Avatar
when it hooks the clutch will take a beating.
why compromise when you can sort out the suspension?
Old Aug 16, 2007 | 10:21 AM
PRAY HRD's Avatar
i don't have adjustable control arms so i can only adj. the front & rear shocks & tire pressure, that's about it. oh, i also have dual airbags that i can adj.
i wasn't looking to compromise, i was told by a few that i would have a hard time hooking with that size tire/gear/trans setup. i'm yet to take it to the track to find out, just wondering in case i can't get it to hook. the 2nd gear ratio would make it similar to racing with a power glide, except with another gear between 1st & 2nd.
Old Aug 16, 2007 | 11:16 AM
Nine Finger 02 Z28's Avatar
Don't do it...Just dial the car in around your setup rather than ruining your car...2nd gear launches as stated above would be very hard on the trans. and clutch...
Old Aug 16, 2007 | 11:23 AM
Grr's Avatar
Grr
i would most def try it. with those gears in 2nd your still close to a M6, 2.73/3.23 car in 1st. and with your weight, no problem. Just try it, one time isnt gonna affect anything.
Gary
Old Aug 16, 2007 | 01:30 PM
zz4camaro1980's Avatar
Gary
+1
1.78 * 4.56 = 8.12
8.12/2.66 = 3.05
It would be like launching in 1st with a 3.05 gear.
If you launch in first and shift at 6000 rpm you will run out of gear at ~37 mph.
If you launch in second and shift at 6000 rpm you wont have to shift till ~56 mph.
When your trying to get the best times your gonna have to be hard on the clutch/trans no matter what gear your in... try it and see if the car likes it.
