using MSD distributor with factory computer
thanks,
Tyler
You can use a front crank trigger along with a digital seven (I assume traction control is what you are after) and use the stock PCM for fueling I suppose. But by the time you spend all that you will be well over BS3/XFI money and that will do what you want.
The stock PCM has a very programmable timing curve
in SD i cant seem to get the timing tables to work worth crap... i can only change the WOT timing from 4000k up by using the "lowest timing" table or whatever its called..... i'd like to use the IAT for timing control but nothing seems to work right since i went into SD....
Most big series dont allow the traction control to be used and they check on the digital 7s.
If you have a 4000 or above converter its all moot anyhow, other then the first 60' or so feet the car will never see under 6000 or so rpm.
Something is wrong if you cant change the timing under 4000, I believe in the custom SD operating systems IAT is no longer there to control spark but infuences a/f like it should in SD.
Either way you are looking at a fair amount of cost and not sure if its worth the hassle for what you are doing. Dont be surprised if some traction control stuff makes its way into some of the newer standalone EFI boxes.
you say the stock engine management has enough spark control but i dont think it does.... i know me and you have talked about it before... and i always see the faster bosted cars- 9.5x and faster using after market EMS....
timing is being just a problem right now and with the stock ecm i dont know of a way around it.... im up for suggestions..
also i agree on the crank wheel being retarted... i have seen ls1's randomly detonate but throw no codes... i can only lean towards the crank wheel moving some since its pressed on... on my build i welded it in 3 spots and then rebalanced it...
But the stock PCM has a limited number things that will affect timing, the stock timing range is pretty broad. Are you looking to do different (switchable) timing at the same load/rpm points? The stock PCM wont work for that..
