Drag Racing Tech
UMI Torque arm pivot adjustment??
Old Aug 28, 2007 | 03:15 PM
bigsticksupra's Avatar
Question UMI Torque arm pivot adjustment??
I got the newer design UMI torque arm and was wondering what setting i should put the front at? Theres a lower hole which is similar to where most torque arms have their pivot points at and then theres a higher hole. Which setting should give me the most traction for drag racing? The car makes about 550RWHP and will be using 315 drag radials. Has QA1's, control arms, etc. etc. Thanks
Old Aug 28, 2007 | 08:18 PM
junior28570's Avatar
I have the same T/A and had the same question when I got mine. UMI suggested I use the upper for the best traction at the drag strip. It works for me.
