need more down low
Trying to look at other peoples setups. Nitrous or a transbrake would be ABOUT the same cost to do. Would rather do the transbrake, if i knew for sure it would fix the problem.
th350, 3200 stall, 3.70 gear, 9" rear, 27/10.5 et streets, procharger @ 5lbs, 234 242 .598 .610 114lsa cam, bolt ons, lcas, ph bar, subframe connectors, umi tq arm. Went to 1/8th track other night. Best 60' was 2.0 & wasnt spinning. Major pig out of hole till it gets up to the powerband. Advice?
you might want to pully the blower down so it comes on herder and use a restrictor on the inlet to control the boost. The vette guys do it on the t trims and ysi's when they want instant power but can't handle 14-15psi up top.
His cam is much smaller then yours
You Should listen to Alex. You need some thing to Capitalize on what you have or want to use
Im going to log a few 1.4mile passes on the 18th. See if theres anything odd in the tune.
Have the converter restalled to a 3800 to 4000, and hang on.
