Drag Racing Tech
What coolant overflow?
Old Sep 3, 2007 | 11:52 AM
a98ws6's Avatar
Default What coolant overflow?
What are you drag guys using and where did you mount them?
Old Sep 3, 2007 | 01:31 PM
tektrans's Avatar
I used a moroso overflow. It's the black plastic one on the left.
Old Sep 3, 2007 | 01:41 PM
JL ws-6's Avatar
Race your car!
I used a summit one, and mounted it where the spare tire goes, the lip of the inner fender worked great as a mounting surface, couple washers and oen extra hole and it worked perfect. Plus, by putting the overflow in the back, if it ever does overflow, the coolant won't hit the tires, and the liklyhood of a wipeout is way less.... which is the main reason I did it.
Old Sep 3, 2007 | 05:23 PM
ls1408cp's Avatar
heres a pic of mine. It is a quart but I will be going to a 1.5 quart for pushing water
Old Sep 3, 2007 | 05:55 PM
Phil99vette's Avatar
7 Second Club
I made one that is abotu 1.5 quarts and its in the back of the car with the battery, fuel cell and water tank. If it pushes water and the tank overflows its behind the rear tires.
Old Sep 3, 2007 | 06:09 PM
JL ws-6's Avatar
Race your car!
Same reason I put mine back there. Not worried about it now, but someday when the bottle goes in, might be a different story.
Old Sep 3, 2007 | 06:29 PM
ls1408cp's Avatar
did you guys just run a rubber line back to it. I wonder if I can put one in the hatch area? that would be along peice of hose.
Old Sep 3, 2007 | 08:18 PM
JL ws-6's Avatar
Race your car!
that's what I did, I ran long *** piece of hose and put it in where the spare usually sits. it works fine, a little it of coolant made it back there this weekend, I didn't have the radiator low enough to start.
