Drag Racing Tech
ABS Pump Eliminator
Old Sep 4, 2007 | 07:05 PM
CTP Racing's Avatar
Default ABS Pump Eliminator
If we remove the ABS Pump is there a junction/splitter i can get to replace Pump. 98 Z-28 Drag car
Old Sep 4, 2007 | 07:15 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
You mean the ABS Block?
If so We Have a direct replacement aluminum block that will eliminate your abs block.
Old Sep 4, 2007 | 07:37 PM
quickta's Avatar
Default abs block
will the brakes act the same with the block installed, can you show a picture of it on the car, also pm a price to me
Old Sep 4, 2007 | 08:28 PM
TwoFast4Lv's Avatar
SJM has a Nice kit to do it all. I recently installed one and it was a nice and very complete kit
Old Sep 4, 2007 | 08:34 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
Yes, you have a pm
Old Sep 5, 2007 | 12:04 AM
SJM Manufacturing Inc's Avatar
Thanks for the compliment Ellis.
Our kit completly removes the whole ABS block as well as bracket. A block is not used, new lines are included in every kit. It cleans up the engine bay opening up well needed room for supercharger/turbo setups. It also allows for better air flow in the engine bay. Pound for pound, it is a VERY good modification. Removing the ABS system will drop ~15lbs from the engine bay.
The kit comes with new pre-formed lines, all fittings optional line lock with master and control switch as well as remote LED...A adjustable proportioning valve is also implemented so the brakes can be biased. When you remove ABS, you remove all bias adjustability that the ABS system handled. The valve allows you to adjust front/rear braking pressures.
Base-line kits which include all fittings, pre-formed lines and an adjustable wilwood proportioning valve start at 139.99. If you already have a line lock and double flare tool, this is all you need. Complete kits are 199.99 which include the circuit components for the line lock (two switches, fuse, fuse holder, wire, electrical fittings...down to the grommet for the firewall), line lock solenoid and double flare tool.
Complete pictorial and written directions are included. If you purchase the complete kit, flaring tool directions as well as a schematic for the line lock solenoid circuit is also included.
All kits are in stock and typically ship within 24 business hours.
