Drag Racing Tech
Engine and Tranny mounting
Old Sep 22, 2007 | 09:09 AM
01ramair500hp's Avatar
Default Engine and Tranny mounting
ok im doing a thumper series turbo 101 or so on a iron block 408. will be running motor plates and a solid mount trans mount. will this make the weak link the transmission housing? the torque arm is mounted on a driveshaft loop. is this setup ok or would you change something? trans is a th400. thx for your help
Hunter
Old Sep 22, 2007 | 12:30 PM
stevemilz's Avatar
Are you wondering about Mid plate?
Old Sep 22, 2007 | 02:54 PM
i have a mid plate also.. im just wondering if everytime i launch my car hard if i will break the trans housing ?
Old Sep 22, 2007 | 03:17 PM
cnorton's Avatar
My LT1 has a motor plate, a mid-plate, and a solid trans mount. The trans is a TH200 that has a notoriously fragile case. I have over 200 runs, many of them quicker than 10.00 with 60' launches below 1.30 and there have been no problems with the trans case to date.
Old Sep 23, 2007 | 10:51 PM
cool that is the result i am hoping for.. thx for your help
Hunter
