Tire height
More hp = more gear = taller tires.
i.e. on my car as a nitrous huffer -- N/A, 420rwhp, 4.30 gears, 30" tires work great went through the traps at 6700rpms. Same engine, same gears, same tires on 150 shot of nitrous (about 600rwhp), ran out of gear at 1000' mark - would have had to change out gears or taller tires (which is not an option)- BUT didn't get a chance as put it on the bumper and broke the engine.
Twin turbo (now): on 10lbs of boost the SS make about 880rwhp; had to drop to 3.50, with 30" tires. Trap about 6800rpm's.
See: more hp, either bigger tires or less gearing.
David
Disadvantage: Running a bigger tire than you need will slow the car down.
If you're thinking of going 15" with a drag radial I would maybe look at a 275 60 15, it will work with your gears and transmission well.
My friend has run 8.30's on that tire with an auto. Another guy I know runs an f-body thats been low 8's with an auto as well.
A 29" drag radial would be too much tire for your power levels now and would most likely make your car slower than if you used one of the smaller drag radials.
David
With the stock rear-end, this would work IMO: 15x10 w/7" or 6.5" b/s. Run the M/T DR 275x50Rx15. The height is a little taller than the 315's, but only .5" (26.1 M/T vice 25.5 BFG's). The M/T tread width is 10.4. This "should" give the contact patch you need and let you finish in the 7000rpm range.
NOW, it would be a little different if say you change out your gears to a 4.10. Than go with the 275x60Rx15 -- almost the same but are 28" vice the 26" tall. -- more side wall with the 60's vice 50's.
Daily driver and very little drag: keep the 3.73.. Daily driver but multi-weekend drags: change to the 4.10.
David
I have a 275 60 15 on my car and it is a hair over 27" tall.
The set of ET Fronts we run are 26" and actually measure 24.75"
Best way before you get any tire is measure it yourself.
A 315 tire will have a tread about 10.50" - 10.75" depending on the brand"
Also I would keep the 3.73's, a 4.10 is a weaker gear (the teeth are smaller) but will add performance in the 1/4, but not much for the price of new gears and getting them put in and as far as gas mileage the difference between 3.73 and 4.10 was not much at all.
I have run 3.42's 3.73's 4.10's and 4.56's in a f-body.
I personally liked the 4.10's all around.
And turbo, blown or nitrous cars can get away with less gear. A buddy of ours runs 3.08's, but then again he has a LOT of power.
