Drag Racing Tech
Tire pressure with slicks
Old Oct 6, 2007 | 05:03 PM
Tim King's Avatar
Default Tire pressure with slicks
Just wondering what kind of psi people are running. Particularly people with 1.35 60ft and under.
Old Oct 6, 2007 | 05:16 PM
kp's Avatar
kp
I run 13-14psi cold with tubes on these 10.5x28s. Depends on the tire size, bigger tires (14x32 etc) way less..
Old Oct 6, 2007 | 06:59 PM
1STGEN68-2000SS's Avatar
12.5 to 15lbs depending on the track conditions. If you are running the 1/4
I would start a little high and see if you can hook without spinning. The lower the tire pressure the more the car will sway on the top end.
Alan
Old Oct 6, 2007 | 07:23 PM
mrdragster1970's Avatar
6 & 8 Second Club
Fast car 5 psi, 1.00's 60', slow car 8 1/2 psi, 1.20's 60'.
Old Oct 6, 2007 | 10:06 PM
WE TODD DID's Avatar
Wheel width, along with tire size is going to be factors in this. 28-10.5 with a 10" wheel, I go about 11lbs and cut high 1.20 60'
Old Oct 7, 2007 | 11:09 AM
Loudmouth LS1's Avatar
I run 12 cold on 28x10.5S M/T Drags.
Old Oct 7, 2007 | 05:35 PM
Tim King's Avatar
I have a 28X eleven and a half(my one button stopped working) I trying to get my 60ft down but the best I've been able to do so far is a one.34 60ft. The car has a 4 link system on it so I think it should be able to do better than that. What would you recommend. Here is a vid and you can see some of the launches. I was told I should lengthen my instant center, what do you think?
http://s85.photobucket.com/albums/k4...iefinished.flv
Old Oct 10, 2007 | 05:51 PM
chrismorales75's Avatar
What's the instant center at now?
What's the pinion angle at?
What's the weight distribution?
How high are the wheelie bars off the ground?
It looks like it unloads the tire, just kind of pops up the front end some and comes right back down to me.
I would list or find these things out before you change anything, you need a starting point to know where you're at and where you need t go.
As far as tire pressure, every car and tire size is different, most people lower the psi till they get the best 60ft without losing mph.
Is your car an auto? Have you tried running a drag radial? The drag radial tire compound is actually softer than most of the slicks that size.
