Drag Racing Tech
A3 Guys,Throw it Neutral at the end of your run??
Old Oct 7, 2007 | 07:54 PM
BTLFEDSS's Avatar
Default A3 Guys,Throw it Neutral at the end of your run??
Just wondering for you guys using RMVB A3's do you throw it in neutral after the traps or just keep it in 3rd???
BTLFEDSS
Old Oct 7, 2007 | 08:06 PM
big thumper122's Avatar
with the RMVB you don't have to...when you're out of the throttle its the same thing.
Old Oct 7, 2007 | 08:10 PM
Loudmouth LS1's Avatar
Not in third!
Btlfed, after I go through the traps, I let off and throw it to 2nd, which basically throws it in neutral, cuz when you are off the gas in first or 2nd, it is basically neutral, forget the exact term for it, but you get my drift.
Old Oct 7, 2007 | 08:45 PM
theblur98ss's Avatar
Do not throw it in neutral. I forget what exactly goes on but the tranny isn't pumping any fluid. When I was calling around about a tranny build that was something every builder stressed.
Old Oct 7, 2007 | 09:06 PM
gator's 99TA's Avatar
i have thrown mine into "second" as the transmission is essentially freewheeling.
now i would never stab the gas as that point as i am on the brakes anyways. mine is a RMVB th400 so i cant throw it into N without first selecting 2,1,N
Old Oct 7, 2007 | 09:08 PM
I've been doin it for years w/o issues. I think what you just said is just a myth, same thing about not cuttin the motor when you go through the traps, yet a lot of people do it to read the plugs (myself included).
Old Oct 8, 2007 | 12:01 AM
LC's Avatar
LC
huh!.. i always just let off and let it freewheel in 3rd to a stop..
Im scared to shift to 2nd and it will go to 2nd instead of N and overrev de crap
Old Oct 8, 2007 | 12:09 AM
GueSS Who's Avatar
Same here
Old Oct 8, 2007 | 01:15 AM
TwoFast4Lv's Avatar
Depending on the valve body and setup you do NOT want to do that. Well unless you want the third gear drum coming to visit you inside the car
Old Oct 8, 2007 | 05:37 AM
9sec93's Avatar
Not in third!
depending on the valve body, low gears (1st and 2nd) do no thave engine braking
Old Oct 8, 2007 | 06:04 AM
Yeah, that's what I was lookin for, 1st and 2nd in a rmvb don't have engine braking, thank you.
Old Oct 8, 2007 | 08:11 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I just get off the gas, I don't downshift I don't think my trans will like that.
Old Oct 8, 2007 | 10:00 AM
DERTY's Avatar
The Bull
Yep, don't change gears. Feel free to let up and coast it around in gear. You also do not want to shut your motor off for the lack of engine RPM's will stop spinning the converter, which ultimately stops pumping the trans fluid around and that's where the fluid/lubricating issues come into play.
Old Oct 8, 2007 | 12:25 PM
so how can one check the true conditions of the plugs?
Old Oct 8, 2007 | 01:08 PM
DERTY's Avatar
The Bull
If you let it idle around the turn you can pull the plugs and the heat/timing mark will still be where it needs to be. You can wipe out the heat/timing mark only if you put heat back into the plug. If you pull the plugs out at the top end you can usually get a pretty good reading right there. I used to carry the socket with me to pull as many plugs as I needed to at the top end.
That little extra around the turn doesn't make much of a difference in the timing mark at all. If you drive it back to the pit area you can potentially wipe out the mark. However, small part throttle back to the pits and I've always been able to get the reading off all of my plugs, no problem. I probably don't need to tell you that the only way to get a true reading is to stuff a new plug(s) into it each pass. You can get a reading off an old plug, but you're better off with a new one.
Old Oct 8, 2007 | 02:08 PM
Hmmm, that's news to me, and from what i've seen in the past, you know ur ****, yet everyone I know has always told me to get a reading on the plugs I have to cut it right after wot cuz they have a very short memory and will change to whatever conditions I have at idle. So ur positive it's ok to idle to the end and turn off and then cut it? And you recommend not goin to 2nd and let it wind down in 3rd (which I also was told wasn't good)?
Old Oct 8, 2007 | 02:32 PM
DERTY's Avatar
The Bull
You definitely do not want to put it back in 2nd unless you have an unbanded drum. If you have drum with no band you essentially are freewheeling the trans anyway because the rear axle speed is faster than your idle speed so the drum is able to spin freely anyway. If you turn the car off though, you will not be circulating your oil while the car is moving and that can effect the clutches, the oil temps in the converter, etc. If you want your parts to last, I would just wait until the end of the track to check your plugs. You're name isn't Pat Musi, Marc Dantoni or Billy Glidden, so don't worry about it too much.
As far as checking the plugs, the timing mark will be on the plug very solid. You just have to worry about the type of plug you use. Some of the plugs have a funky coating on them and that can mess with getting a reading because you have to scrape that coating off to see the real timing mark. I always used a non-coated Autolite plug and the timing marks were always solid after making the turn.
If you're really concerned about getting data off your run you would probably want to start looking at using a Racepak setup instead anyway. The plugs are only going to tell you so much. If you are really interested in every inch of your run you wouldn't look at the plugs as much as you would your entire run data. There's a steep cost to adding the Racepak and it's why most people get by with just the plug readings. It's really worth it though in terms of getting a good look at all aspects of your run.
Old Oct 8, 2007 | 02:42 PM
So it's ok to throw it to 2nd (basically neutral with my trans) after the traps, but not ok to shut the car is what i'm gathering from that, correct?
Old Oct 8, 2007 | 03:14 PM
kp's Avatar
kp
The 'shut off the car to get a plug reading' thing is more for carb'd cars that run at 9:1 a/f at idle and dump a crapload of fuel on decel.
Most modern EFI cars will pretty much shut the fuel off (DFCO, BS3 has it) once you dump the throttle. Even if you drive it back a little the 13-14:1 a/f wont color the plugs.
As far as putting in 2nd (neutral on a TCI TB valve body) most of the time I dont but I could if I wanted to. I'm usually too concerned with stopping than farting around with the shifter at 140-150mph. The first 60 foot of slowing down is almost as important as the first 60 feet of taking off.
Old Oct 8, 2007 | 03:25 PM
DERTY's Avatar
The Bull
For the most part (and KP summed this up too), there's no net gain for putting the car in 2nd for any reason until you get down to the turn and want to put it in the lower gear. Of course this assumes you have an unbanded 2nd gear which would allow you to do that otherwise you could have a very bad day. At the end, it's your choice.
