Drag Racing Tech
Fuel Supply/return && Cable routing
Old Oct 20, 2007 | 03:36 PM
Phil99vette's Avatar
7 Second Club
Default Fuel Supply/return && Cable routing
I'm trying to find the best place to route the fuel supply & return and the battery wires under the car. Here is the problem.
Normally they would be routed under the driver or passenger between the frame rails but with the 25.5 chassis there is 3 - 2x3 outriggers on each side. I could route it there but it would end up being the lowest point of the car which I am not happy with.
Should I route them through the corners of the inside of the cabin?
I could do some 1.25" through tubes in the outriggers..
Old Oct 20, 2007 | 03:45 PM
chrismorales75's Avatar
The battery cable inside the car would be fine, but anything fuel related should be outside of the car.
I would use a piece of square tubing maybe 1 1/2 by 1 1/2, cut one side off so you have a "U" then you can cut into the outrigger as deep as you need it to fit up inside and weld the seams and you have your channel, plus it will still have some strength with it welded back up.
